Can't delete added points / split lines in floor sub element
Message 1 of 25
Please help,
I cannot manage to delete any point I add to modify the floor.  The Autodesk help simply says to select the element and hit delete or right-click and select delete; however, neither of these options work.  The only way to delete any added points is to click "reset shape", but then the every point I've added is gone and causes a huge headache by starting all over.  Has anyone else had this problem and know how to resolve it?  I've attached a picture showing the delete button greyed out.
Thanks!
P.S.- I am using Revit 2018 on Windows 10 on a Macbook Pro using Parallels.
Replies (24)
Message 2 of 25
ennujozlagam
@Anonymous hello, it wont work when using your mouse right click to delete. window your point to delete and use your keyboard DELETE to delete. thanks
Message 3 of 25
Even if I click on the point and hit delete on the keyboard, the point is not deleted.  I'm able to move the point and change it's elevation - I just can't delete it!
Message 4 of 25
ennujozlagam
@Anonymous hello, you cannot delete corner points. post your floor so we can check. thanks
Message 5 of 25
See attached image.  I know I'm not able to delete the green floor boundary points, but I added the four blue points and should be able to delete those.  Thanks in advance.
Message 6 of 25
ennujozlagam
@Anonymous  hello, can you untick the x in my screen shot and see if helps. i really don't know until i see your file. thanks
or cut and paste your floor in a new file and post it here. thanks
Message 7 of 25
I've attached my file.  Basically I'm trying to modify a floor by adding points and modifying the elevation of each point to represent the landscape.  It's basically a flat site, so not much manipulation is needed.
Message 8 of 25
ennujozlagam
@Anonymous hello, i can add elevation points and can delete also. thanks
Message 9 of 25
Maybe it's my computer then...thanks for your help.
Message 10 of 25
ennujozlagam
@Anonymous hello, just install latest updates from autodesk and see if helps. thanks
Message 11 of 25
ovlagkouli
Select the floor you want to edit and then click "modify sub elements". Once the outline turns green, then draw a rectangular around the point you want to delete and press delete on your keyboard.
Message 12 of 25
You did notice you are responding to a post from over a year ago right?
Message 13 of 25
la1806645
even though the post is old your reply helped me now. thank you!
Message 14 of 25
ovlagkouli
Glad to be of help
Message 15 of 25
This guy's got it. I wanted to post so others find this answer. Thanks!
Message 16 of 25
ovlagkouli
4 years later since the question raised and still useful. Nice to help, hey?
Message 17 of 25
PhilvK
And STILL a helpful post in June 2022!
Message 18 of 25
mara.deacon
Observer
Observer
it helped me today - August 22. Thank-you
Message 19 of 25
marc.khalil
I had a similar issue today where I have a point I couldn't delete. And I discovered the problem: one boundary edge was in two pieces instead of one. Once I made that edge into one piece, the point was gone. So for anyone in the future who finds this thread because of a similar issue: check your boundary.
Message 20 of 25
tbagot
Community Visitor
Community Visitor
I am having the same issue except i cant delete any added points
