CAN'T CREATE BEAM SCHEDULE
1 REPLY 1
kalktika
203 Views, 1 Reply
kalktika
Hi, I'm not able to create a beam schedule  even when I choose the right phase. When I create the schedule it's empty.
1 REPLY 1
ralphdenhaan
in reply to: kalktika
ralphdenhaan
Are you using the Beam System function in Revit or modeling the Beams individually? Try to create a Structural Framing Schedule instead. Maybe you can attach your file here?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
