When I create a split region, I get the split region height dimension in the section preview of my wall type, but when I go back to the wall type later in a session, the dimension does not appear, even if I click the region split line. Any clue why this is happening?
Solved by barthbradley. Go to Solution.
See if the video embedded into this article helps:
If you upload screenshots it will be easier to help you
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You know, I could be a Graphic Card issue. Don't know if this will help, but try disabling hardware acceleration.
...maybe a driver update is available.
Are you sure you did click Edit to enter Wall Structure and not still under Wall Type preview?
I think you're right in that I may have been running out of ram at the time.
If it wasn'ta memory issue as I mentioned in the response just before this, it was something in the procedure I was following. In any case, all the work was done in the 'edit' mode. I redid some and it's working now. Thank you.
