Can revit put 2 parameters in one column in a schedule for a drawing list?
Stephm419
Stephm419
My workflow for sheet numbering is required by some cities.
I know about making the sheet number and putting it in a schedule. In the image I currently do it like for drawing E-103.00 and towards the end.
However, I need to have the last two digits to be a revision number. Like the first 3 drawings listed.
I need to have the top 3 drawings E-101.01 look like the E-103.00.
In other words, how do I get the (2) parameters in one column in a schedule.
Yes if you are using Revit 2017.
Sahay_R
In 2017, you will need to use Combined Parameters.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Stephm419
Is there anyway for 2016?
No.
You could write a dynamo script to read the two fields and write them into another field.
dynamobim.org
