hello, how to recover file when Revit gave me this message (can not open the file there is missing many elements), how to solve that, thank you in advance.
can you tell me please how to send you the file? i tried and i cant attach it.
thank you
you wrote
hello, i can not attach the file, thank you for the help
why? you can zip the file or use dropbox or others website to upload and share the link. thanks
https://www.dropbox.com/s/tjtc8halj5qyoup/office%20building-not%20working.rvt?dl=0
that the file,thank you
sorry i tried but the file is corrupted? the only person can help you is from autodesk? try to PM this person LINK. thanks
you can refer to this LINK.
here is some tips to recover:
When you try to open the model, an error displays indicating that the model is missing many elements.
Issue: In some cases, the error displays and the model opens successfully. When you examine the model, you may notice that some elements are missing.
In other cases, the error displays and the model does not open.
This error is generally the result of element-level corruption in the model.
Solution:
%LOCALAPPDATA%\Autodesk\Revit\Autodesk Revit 2020\Journals
If needed, zoom and pan the view until you can see the elements clearly.
If needed, zoom and pan the view until you can see the location where the elements should display.
The audited backup model becomes your new working model. Rename it accordingly. Also rename the corrupt edition of the model in case you need it for further troubleshooting.
I will read what did you suggest, thank you so much for training and for the help.
Try to open a backup version... and you should audit your models at least once a week.
hello, what did you mean by that (you should audit your models at least once a week)?
thank you for the answer
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2019/...
Hi @Yara-architecture You could read something about auditing in the link above (...sentence four).
