Can not control Input topography points trianglation 无法控制场地导入点自动生成的边界点
- Mute
- Permalink
- Report
I have a regular surveyed pts as a input Toposurface. I can import a already trianglated file from microstation or C3D which can restricted these pts trianglation edges maximum length such as 5m. But when I --> Modify | Edit Surface tab, click Tools panel-->Create From Import drop-down--->(Select Import Instance). Revit will built new trianglation and insert new boundary points.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-B79E6DD1-54B0-4596-80C9-2A2ADD1F58A7
- Visibility. You can control the visibility of topographic points. There are 2 topographic point subcategories: Boundary and Interior. Revit classifies points automatically.
These regular points are imported points, outsiders are Revit produced. Now I want to delete these outsiders (too many, over 5000), I can use the Split a Toposurface function to delete all these Revit built topography. But it's waste of time.
Is there a function can create a toposurface only from imported data or the toposurface's trianglation edge maximum length can be defined.
我有一个场地测量文件,规则的测量点,1m一个,场地边界长弯弧形不规则,导入到revit后,revit自动添加了很多很多的外边界点,生成一个近似矩形的场地。我不想要自动生成的场地,因为外边界点都是Revit插值得到的。可以用拆分表面来删掉它生成的出了我想要范围边界的表面,但几千个一个个拆分,太多工作量了,有没有简易的方法。像Microstation或者C3D那样,可以控制生成曲面的三角形的最大边长。
