Okay, I have created successful square spread footing under the concrete slab. That would be to support the load-bearing column. And I attempted to do the same thing for the rectangle spread footing to support load-bearing wall that also supports the roof above, and it won't complete the sweep. I am puzzled.
What is different between Square that I can complete the sweep and Rectangle that I can't complete the sweep?
Attached are two files. First one will show the spread footing that shaped like U. That completes the sweep but looks like U shape. That is not right. Second file shows I had attempted to do the same thing using the successful square spread family, then I modified to rectangle, which should be simple yet I get the error message.
