Can I synchronize two views to move at the same time?
Message 1 of 8
I'm working on a Floor Plan and Ceiling Plan at the same time, but I have to move them both separately. My question is, is it possible to move my Floor Plan and my Ceiling Plan moving at the same time as one? I have not seen any post of this but I believe there is a way to simultaneously move together. I hope my question is understanding.
Replies (7)
Message 2 of 8
rodrigo.bezerra
Can you be more specific about "move 2 views simultaneously"? You're putting one view over another in a sheet? Maybe add some screenshots.
Regards
Rodrigo Bezerra
Message 3 of 8
When I move my Floor Plan I want my Ceiling Plan to move at the same time. I have my Floor Plan and Ceiling Plan open at the same time but it is a hassle dealing to move one and move the other after. I usually close my ceiling plan and when I'm at another location on my Floor Plan and reopen my other plan. I do not know if this is possible but I might have seen this work somewhere or some other Autodesk program.
Please See Attached Photo
Message 4 of 8
rodrigo.bezerra
Sorry, but when you said "move" I did not understand that you actually means "pan".
I stepped into this thread in Revit Forum <http://www.revitforum.org/architecture-general-revit-questions/21327-two-synch-views-possible.html> where they talk some ideas (I could check it out thou). I was going to suggest to use underlay but you're already using it for another purpose. Check the link out and maybe it gives you some ideas.
Sorry I couldn't help more. Regards
Rodrigo Bezerra
Message 5 of 8
Rodrigo,
Thank you for the help appreciate it much.
Luis Barillas
Message 6 of 8
Have you looked at ViewSync on the Revit Exchange App Store?
Message 7 of 8
ggranadosNFAMX
Check Sync Views on pyRevit.
Message 8 of 8
RMN_D.Stemberg
yes the SyncViews on pyRevit is doining exactly what you want.
