Can I copy a custom family parameters from one family to another?
I created a whole bunch of custom family parameters in one family.
So as not to be redundant, how can I copy these exact parameters to other families?
GHASEM_ARIYANI
Hello @Anonymous
Maybe solve the feature Shared Parameter
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
PrathapSekar
@Anonymous,
As I understand from your post you created family parameter if you want to share your parameters across the projects and families you have to create shared parameter file, to export your family parameters to shared parameter go through THIS...
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
