Can I combine or put together two or more revit files into just one ?
We have different revit files for each part of the project but we would like to put those together for some external studies. Is there a way to combine those files into one file?
Thanks in advance.
aRcHiTeCt.JM
… hi @Anonymous
…. you can link and bind the pieces into one
…. follow these links:  Link and Bind
…. my recommendation: save everything as a copy
…. do not replace your original files
….. you will lose some info within your project
…. but it will work for some additional analysis
.... unless you are ok re-dimensioning
..... and re-doing some of the project elements
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
So you want to combine several Project models into one Project? If so, use "Load as Group" on the Insert Tab.
Thank you, in my research I found something like this. This will work for me.
Thank you, I will be trying this option in the future.
