Cameras not rendering properly - RVT 2018
jrrodriguez7VTDA
Observer Observer
jrrodriguez7VTDA
Observer
Observer
Please  i need some explanation of how to make my cameras render properly again. In my Project i have more than a dozen cameras placed and configured. But suddenly they all tend to render, omitting almost all Floors Families, Lights, Walls ETC.  Please see the images  to understand what i'm saying. And if you have a solution, i'll gratefull. 😁
Hit the first with some Post Rendering Exposure Adjustments (e.g. Brightness). Second one ain't a Rendering.
jrrodriguez7VTDA
Observer
Observer
Hello, the left image is a render  i took from the image of the right. So as you can see there's no walls, lights or cars. A lot of families dissappear when i process the render. Any Help?
aRcHiTeCt.JM
... hi @jrrodriguez7VTDA
... you do have a corrupt family
... that usually happens when a family... specially rpc's from archvision are corrupted
... but for sure is an imported family
... try to hide all of those and render it again (just to make sure those are the ones causing the issue)
... then ... find the trouble one and delete it
... and delete all temp files in your pc
... c:/users/xxx/appdata/local
... c:/windows
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
jrrodriguez7VTDA
Observer
Observer
@aRcHiTeCt.JM , i try everything you said but still have no results. i put new cameras and worked for me for one time then and i close the project and when reopened the problem seems to be the same.
Do you have another solution? Thank you.
bill_gilliss
Try auditing the model next time you open it. To open it, DON'T click on the file on the Recent Files launch screen, but use File > Open and check the Audit checkbox:
