Camera orthographic/perspective toggle?
As far as I can tell, there is no way to switch back and forth between perspective and orthographic projection on an existing camera, anyone have a solution?
LisaDrago
I don't know of any way of changing this. Any camera view you take is going to be perspecitve. any view from the default view will be ortho.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
lionel.kai
This is an old thread, but maybe someone is still finding it while looking for the answer:
Make sure "Crop Region Visible" is checked, then right-click the View Cube and choose "Toggle to Perspective-3D View" (or choose "Toggle to Parallel-3D View" to go back).
Lionel J. Camara
BIM Manager at KAI Hawaii, Inc. - Structural and Forensic Engineers
Autodesk Certified Professional
moneech
Observer
Observer
thank ou so mush
solved
lionel.kai
Of course it's much easier now (in Revit 2019): just change the "Projection Mode" property (under the "Camera" group) to "Orthographic" or "Perspective".
Lionel J. Camara
For a second, I thought your last name was Camera and you were selling the family's secret tips and tricks 🙂
