Callout tag problem: Line through detail number
Marcus.Isacsson
Message 1 of 10
Marcus.Isacsson
Hi fellas!
How can I avoid this from happening?
Replies (9)
Message 2 of 10
The Text in centered on the Origin Ref. Plane. Move it to the side.
Message 3 of 10
Marcus.Isacsson
Only seems to fix it on one side (right or left). Would be a bummer if I need to have two different families.
Callout left & callout right to make it work. Maybe I'm missing something.
Message 4 of 10
Leave it where it is and put a mask behind it
Message 5 of 10
Marcus.Isacsson
Just noticed a new problem (when placing vertically):
Message 6 of 10
Make the mask smaller. Best to constrain it to the size of the text box.
Message 7 of 10
Marcus.Isacsson
Works great horisontally, but when I move the detail number to a vertical position it get's messed up, unfortunately.
Message 8 of 10
Messed up how?  Post what you've done so far.
Message 9 of 10
cesc
hiya,
did you find a way around this? I am having the same issue...
Message 10 of 10
cesc
actually I think I have found why. The lead is cut to the longest dimension, and in this instance it is the horizontal.
I am wondering if it is possible to do non circular/square callout tags?
