Calculated Value - inconsistent units
Message 1 of 9
CaptureA.PNGi Want to multiply the volume by 500.
Replies (8)
Message 2 of 9
A Volume times 500 is still a volume. Your parameter is Number that's why. Either change the parameter to Volume, or change the formula to (Volume/1)*500.
Message 3 of 9
500 IS THE NUMBER OF BRICKS PER M3..IF I DO IT LIKE THAT THEM I GTE AN EMPTY COLUMN.
Message 4 of 9
(Volume/1)*500
Message 5 of 9
It works but the column in empty
Message 6 of 9
Strange.
Message 7 of 9
Message 8 of 9
i was selecting the volume column and then pressing calculated value..............so the volume column was replaced by this column hence the value Nil.........
Message 9 of 9
jacobusJBFYP
Volume/1 works perfectly. Thanks a lot.
