Calculated Value Conundrum
emodderman
emodderman
Hello!
I have a schedule with a calculated value that returns no value! I can't figure out why... I've checked out other solutions here and they have not worked yet...
I have a schedule with many parts of a curtain panel family scheduled. I need the total cost of the Panel, based on the sum of the individual part costs. The part costs are also a calculated value, and this value works fine. What I am trying to do that is returning the 0 value is add up the sum of the PART COST (LENGTH) column and the PART COST (AREA) columns.
PART COST (LENGTH) formula:
COST PER * ((PART LENGTH / 304.8) / 1 mm)
PART COST (AREA) formula:
COST PER * ((INFILL AREA * 10.7) / 1 m²)
Total Cost formula:
[PART COST (LENGTH)] + [PART COST (AREA)]
OR I have also tried:
(COST PER * ((PART LENGTH / 304.8) / 1 mm)) + (COST PER * ((INFILL AREA * 10.7) / 1 m²))
the second formula makes the requirement of the individual part cost per area or length columns obsolete, but it still returns an empty cell or a $0.00 value.
This also brings me to another weird thing...
When I UNCHECK Itemize Every Instance, I get a $0.00 value, but when I CHECK the Itemize Every Instance, I get a blank cell.
All my values are currency, formatting should be correct, I'm totally all the columns I can think of, but even when I don't, nothing changes.
I cannot upload this file, there is too much information to share here...
Is there a reason you can think of that would prevent the Total Cost column from displaying a value?!
Itemize and make sure no cells are Blank.  All Blanks must be filled with 0.  After that, you can unitemize and it should work.
emodderman
Hm. There is no way I can get all blank cells to display 0. Some of the parts do not have a Part Length or Infill Area parameter... It's one or the other.
I guess I'm not going to make this happen! But it's good to know the rules here.
Thank you!
Thank you!
Edit [PART LENGTH] material in the schedule and tick Add to all elements...  repeat for other parameters that need to be in the formula.  Then you should be able to fill 0 to blank cells.
emodderman
but the parameter is inside each component part... so will just adding the parameter as a project parameter work for the ones that don't have it already? I think I will end up with two columns instead...
It's quite a complex family with lots of connected parameters and nested, shared families, so basically I have to weigh the advantages of being able to get a total in the schedule against adding unnecessary parameters to all my components...
project is on hold for now, but I will try it out...
