Calculated Parameters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All
Having a wee problem with calculations within a wall schedule
I can create a wall type and wall schedule to calculate the area of a specific type of wall. That is the easy bit.
The complicated bit is that one of my wall types is insulation and the insulation will wrap around structural framing. I don't have time to wrap the insulation around all of the members at this stage of my project, just now all i need is a rough estimate for costing and weight calcs. In excel i would add a column called wrapping factor for example 1.5 and i would get excel to multiply the wrapping factor by the wall area. So if the wall area is 100sqm and the wrapping factor is 1.5 my total wall area will be 150sqm.
I have created a new "type" parameter and called it wrapping factor and when i do that i can enter a value of 1.5 or whatever i want.
Then i create a calculated parameter called total area and go formula and enter area*wrapping factor hit enter and the total area field is always empty.
This seems so simple but for the life of me i can not get this to work
If you can help me i will really appreciate it
Regards
Paul
