Calculated Parameter Formula
DrakeCanyonArchitecture
I know this is going to be super simple for one of you. I would like to take my length information here to multiply by a factor such as 1.1. So what I'm telling Revit is that I want to count 1.1 studs x my length field, I would then have a parameter that would display 268 studs, rounding up of course.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
EATREVITPOOPCAD
Not sure if I understand exactly what you are asking but this is my guess.
Note: you only have to divide by 1.0' if you are using imperial units (to cancel feet out and convert to an integer)
The definition of insanity is doing the same thing over and over again and expecting different results
@EATREVITPOOPCAD <--The name cracks me up. Lol. Here is what I get. The formula feels right but I get <varies> as a result. I'm working in the Schedule Properties to create the calculated parameter.
Kevin Mendenhall
Just got it, I forgot to 'Calculate Totals' in the Formatting Tab for the result. Thanks @EATREVITPOOPCAD 😁!
Kevin Mendenhall
EATREVITPOOPCAD
Thank you for the name compliments 😄
You are getting this result because walls are not itemized in the schedule. What you have to do is itemize them, and then calculate the totals.
