Can't make window error
15 ANTWORTEN 15
Nachricht 1 von 16
mkERY8J
738 Aufrufe, 15 Antworten
I have a file that is now giving me issues and I'm just at the end trying to finish up some revisions. Needing to add windows but now it won't let me and starts deleting windows as I try make new ones. It won't even allow me to input the Revit windows from the library since the windows I had were third-party and I've been using that model for years. (yes it is updated to the current version of Revit I have which is 2023.) Also, I try cutting simple lines and it gives me an error and shuts down the file. I'm not sure what the hell is going on...any thoughts?
15 ANTWORTEN 15
Nachricht 2 von 16
als Antwort auf: mkERY8J
Sounds like disaster. Post the File here and let us take a lookie see.
Nachricht 3 von 16
mkERY8J
als Antwort auf: barthbradley
Sorry, not sure what you mean as this is my first time posting. Do you mean post the entire Revit file?
Nachricht 4 von 16
You can post the RVT here for us to look at and troubleshoot - assuming the issue is replicable on our end.  If you want to do that, start a reply post and scroll down to Attachments and press Browse to locate/select the file to upload with in the reply post.  Get it?
Nachricht 5 von 16
mkERY8J
I will post it so you can see. It's very strange and I have zero clue how to fix it.
Nachricht 6 von 16
Turn off your Imported Categories in the View and let me know if that resolves the issues you are having.
BTW: I'm not having any issues like you are describing.
Nachricht 7 von 16
Ah, I see another possible culprit. Your building Model is located far away from the Internal Origin.
Nachricht 8 von 16
mkERY8J
Ive never had that be an issue before a d how do I fix that if it is the case?
Nachricht 9 von 16
Are you saying that all was well with this Model until recently? Like I said, I'm not experiencing any issues like you described in you intro.  Perhaps those issues are unrelated.  Did you recently install some Add-ins?
Nachricht 10 von 16
mkERY8J
Yes, correct. No issues until last night and I didn't update anything. Very strange. And I cannot see how it would be a virus. Just seems like something glitched in this file.
I'm heading back to the office and will look at it shortly and try your suggestions.
Nachricht 11 von 16
mkERY8J
Removed the entire imported cad file. I keep getting this attached below.
Nachricht 12 von 16
Sorry, can't replicate.
Maybe some routine file maintenance is in order.
Best Practices for model maintenance in Revit | Revit | Autodesk Knowledge Network
Nachricht 13 von 16
Maybe disabling hardware acceleration (under Options) would help you. You've got a lot going in your views. Maybe your graphics card isn't up to the task.
Nachricht 14 von 16
mkERY8J
I'll try that but I've had larger files with more complex homes without issue. I'll just make sure that I don't use this as any other template so that it doesn't haunt or follow other files. I'm not sure what you mean about "file maintenance" but I'm open to suggestions.
Nachricht 15 von 16
Did you see the link I posted?  Guess not. My bad. I'm often editing my posts to include additional info.
Nachricht 16 von 16
mkERY8J
Thank you for the link for the maintenance. I'll make sure to update my routine for files.
