Hello all,
How can I calculate the volume of a building? Each level has a deferent form.
I created different Masses for each level and I found the total sum.
Is it correct this approach? Is there any other way?
Thank you in advance!
@mairh_tsek wrote:Hello all,
Mass is one way, especially in conceptual design.
Another way would be to use Rooms (w/ Areas & Volumes Enabled) and calculate itemized and total Volume in a Room Schedule.
Thank you for your answer.
So is it correct the image below? (If the building has this geometry)?
As the project is an early dessign we dont have yet define the rooms.
