Calculate a total weight by mark in schedule
aaautoglaze
aaautoglaze
Trying to build a schedule we will use for a delivery schedule based on weight by mark. I want the schedule to have a calculated total by each mark. I have the calculated parameter setup and working but I have to create a different schedule for each mark. Is there a way to do this on the same schedule and preferably a break at a given weight like a max truckload of 40k lbs?
mhiserZFHXS
Why do you have to create a different schedule for each mark? What are you doing in the one that prevents all of the marks from showing up? A filter?
Once you get that figured out, add another calculated parameter for certain weight ranges. If its just a single one, like over 40k, just use a yes/no parameter with the formula set to >40k, then sort your schedule by that parameter as well as anything else you're sorting by.
Let's see what you are doing. Post your File.
