Your Xref Lighting Masterplan file and 01-ALL-ROADS_2022-04-29_MRT files have a Named UCS "DefaultLocation-Revit60". Delete those and they should all line up in Revit properly. After deleting the Named UCS in both files:
- I linked 01-ALL-ROADS_2022-04-29_MRT first and used Acquire Coordinates and it appeared in the view in the same orientation as your examples with the black background, the same way it appears in AutoCAD.
- I linked the RVTLINKS_SAS_G_LOW_CE_SCOPE-PHASE1 file using Auto - By Shared Coordinates and accepted the message, landed in the correct location.
- Last I linked the XREF LIGHTING MASTERPLAN file (same as second file) and it lands in the correct location.
The reason there is a named UCS is that when you use Acquire Coordinates on the DWG Revit saved the UCS to them. If you see a message, when you save a Revit project, asking if you want to save the changes to a DWG link choose the bottom option to ...Disable Shared Positioning...
Let me know how it goes.
Steve Stafford
