CAD file fails to be imported,
JamaL9722060
JamaL9722060
As I attempted to import dwg file, I got the message below. What might be the problem?
The dwg file is attached
Thank you
Best
Jamal
Jamal Numan
pendean
Community Legend
Community Legend
On that popup, the sentence in black in smaller letters explains the fix needed.
JamaL9722060
many thanks.
the dwg is already exploded, nevertheless, the problem is still there!
Jamal Numan
CoreyDaun
I was unable to open your .dwg file to test (I only have Revit 2013 installed at the moment), but I have read about a possible solution in the past that instructed to purge out all blocks and delete the existing Layout tabs. All of your geometry is in Modelspace, right?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
Many thanks for the answer.
I’m attaching the dwg file with version 2000. I purged but the problem persists to exist.
What might other solutions be?
Jamal Numan
CoreyDaun
The source of this error appears to the OLE Object, the imported image. See image below. Upon deleting it and importing into Revit, the error desisted. The image does not appear to come through at all when imported.
I will suggest importing the dwg file into a new Detail Item Family. Then you can import the image into Revit from there. Load this family into Revit and you shouldn't have any more issues with this.
JamaL9722060
Thank you for the prompt answer. Sounds to work fine. Very much appreciated.
Best
Jamal
Jamal Numan
