c3a error
c3a error
c3a error
I'm having an error when I start revit 2017.
Using Windows 10.
This is a problem because I need this for my schoolwork.
Please check my images i've add to this post.
Kind regards,
Tibbe V.
From your screenshot, you're not looking in the same directory as Revit is looking.
ennujozlagam
@Anonymous hello, Try to uninstall and reinstall the program, don't install any third party add-in and see if there are any issue. Thanks
Before you go uninstalling and reinstalling....go to that directory where that dll is...select, right click, select propeties.  Check to see if there is a Security message at the bottom of the General Tab and select the button next to it so it enables the DLL..
disclaimer:....if your system gets hosed, I am not at fault...blame where you got that C3Admin addin from.
Kimtaurus
Ik denk dat je best C3A contacteerd. Zij kunnen je via de telefoon verder helpen of via Teamviewer.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
