BY LINKED VIEW settings keep resetting after synchronization in Revit 2024
valentina_stoyanova
valentina_stoyanova
Hi Everyone,
This topic was discussed here and in other forums but I can't seem to make it work for the current project.
We have a parent file on Revit server and multiple models on a local one linked to it. User A created views in the parent file with display settings assigned By Linked View for the links. Unfortunately, most of these settings were reset to By Host View after synchronization.
There is a view template assigned to the views in the parent file with the V/G Overrides RVT Links excluded, so they can be controlled individually for each view.
We tried the operation without a view template but the issue happens again.
Has anyone had such problems? I would appreciate some help in resolving them!
Val
RSomppi
It sounds like the parent file "sees" the links as new models and resets the V/G settings.
