Bump image visible in view but dissapears when view is rendered.
vaseema.hussain
vaseema.hussain
The Bump pattern shows up fine in Realistic mode but when I render the view it disappears. My Graphics Card is Intel(R) UHD Graphics 620.
How do I get the bump to appear when rendering an image?
constantin.stroescu
as I remember it happens to me too some time ago...a difference of scale between the Preview and Final Render...usually in preview the map appears bigger....I do not have an explanation for this, and it doesn't happen to me for a while...
Constantin Stroescu
vaseema.hussain
hi Constantin
Thank you.  Did your issue fix itself or did you continue without it? I am currently stuck as I need to create renders including the bump pattern but am unable to. Is there another work around to achieve what I need.
