Building Pad Problem: Glitch - Graphics Error?
I have come across a glitch from the building pad I just created. This weird surface has been created when I made the dark rectangular building pad on the bottom left corner of the site. Regardless of pad shape or height this surface (not editable as well) remains.
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community!
What is the height offset from the level? Check your building pad properties.
Do have existing and demolished phasing in your model?
Viveka_CD
Hi @Anonymous
I wanted to check back in with you on this post. How is everything working out? You are welcome to post a file for troubleshooting.
Thank you and I look forward to your reply update.
