Show only
Search instead for
Hi - I need to model a building that cascades down a steep sloped hill. Should I create a toposurface first and then model onto that or should I make my model and then apply it to a toposurface?
When I have such a problem I ,first , make the Toposurface , then I made the Building Pads , place the Levels and then begin modeling. I think that architecture has to follow the terrain and to adapt to the environment site.
For more complicated or large projects you can use linked files...the terrain on one file and the building on another file. This can be a more suitable method ..you can work ( or a team can work ) in the same time the terrain and the building...
Anyway , you can begin with the building , but you will have problems when adjusting the levels to fit the terrain...that's why I did not recomand this method...
