Bug with schedules - Version 2021.1.8
barskyd
barskyd
For all types of schedules, if you change the text using Font and then you assign a View Template, the Font button greys out even though the Font settings supersede the View Template.
To change the text once more, you need to remove the schedule's View Template before you are able to change Font settings.
HVAC-Novice
Were you able to replicate that with newer versions? If not, then at least you are sure this is limited to the old versions.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
