bug Slanted and Tapered Walls
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 24
GHASEM_ARIYANI
Hello
Please fix the appearance Air Material Wall Layer for the Section box to the Walls.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (23)
Message 2 of 24
kimberly_fuhrman-jones
@GHASEM_ARIYANI  Have you posted this to the Revit Architecture forum? If not, I may move this to that forum to get support on it.
Kimberly Fuhrman-Jones
Revit Community Manager
Message 3 of 24
GHASEM_ARIYANI
hi @kimberly_fuhrman-jones
Please move to the forum.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 4 of 24
wr.marshall
related idea (maybe same); Cavity Wall - Autodesk Community
Message 5 of 24
I can't replicate.
Message 6 of 24
@GHASEM_ARIYANI  I wonder if it's a graphics issue? Does it go away if you zoom in or out?
Message 7 of 24
Actually, I can replicate. Not a problem though. Air with no Transparency corrects.
Message 8 of 24
GHASEM_ARIYANI
Please Change Material Air Layer to "Air".
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 9 of 24
GHASEM_ARIYANI
yes. I know Air without transparency is OK.
But I say why should this be a problem when there are solid layers behind an air layer
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 10 of 24
GHASEM_ARIYANI
thanks @wr.marshall
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 11 of 24
Message 12 of 24
GHASEM_ARIYANI
no, I think it is a bug for how to display the wall layer.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 13 of 24
GHASEM_ARIYANI
Please read the question carefully and then answer
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 14 of 24
What do you mean?
Message 15 of 24
@GHASEM_ARIYANI : You seem to be implying that I didn't read the question carefully.  Which one of my posts signaled that? The one where I said that I can replicate the issue?
Message 16 of 24
wr.marshall
I am guessing that the issue is that the tapered face after the air layer, should be showing, instead Revit tends to show the background and this face is invisible. This same issue occurs with vertical walls(likely slanted too - not tested) if a middle layer is "air". I think what @GHASEM_ARIYANI is after is to view the face after the air/cavity layer like this screen shot.
Currently no solution. This will require a fix from Autodesk
Message 17 of 24
Yes, I understand the issue. I'll bet it is related to another 2022 issue*** that I and other Users have experienced.   I'm hoping it can be resolved in the first update.  In the mean time,  removing Transparency from the Air Asset or using Parts seems to be a fix in this case.
***another 2022 issue:
Message 18 of 24
syman2000
This isn't a bug. This exist in previous version as well.
If you set the wall transparency to 100%, this is why you are able to see thru your wall cavity.
If you change it to 0, it will show up as solid.
Message 19 of 24
andrew_parrella
This is a generic issue for air layers in walls in realistic views when cut by a section box. It goes back to at least 2020 and I bet much farther than that. I have filed it to be addressed.
Andy P
Principal QA Analyst - Revit
Message 20 of 24
