Bug Revit 2019 - Exporting NWC does not work
smorrison7JDPT
Message 1 of 20
smorrison7JDPT
I am also having the same exact error message when trying to either "export as NWC" or use external tools-Naviswork 2019. This error does not occur in revit 2018 and navisworks 2018. Ive uninstalled Navisworks 2019 and reinstalled. After doing so I still have this problem. Has a solution been found?
Replies (19)
Message 2 of 20
Viveka_CD
Hi @smorrison7JDPT
Sorry to hear that you are facing issues.
Please post a screenshot of your error message and diagnostic data. I can send you a private upload link.
Looking forward to hearing from you!
Message 3 of 20
smorrison7JDPT
Thank you for the reply. I have posted my screencast for review.
Message 4 of 20
smorrison7JDPT
Please see screencast for clarification
Message 5 of 20
smorrison7JDPT
Message 6 of 20
smorrison7JDPT
Hopefully screen cast appears
Message 7 of 20
Viveka_CD
Hi @smorrison7JDPT
Sorry, I still do not see your screencast, you can also post a link and try in a different browser.
Message 8 of 20
Viveka_CD
Message 9 of 20
GHASEM_ARIYANI
I feel the problem is with the manifest file on your system. Because I work daily with Revit and Navisworks And there is no problem.
I suggest Replace the DLL files from the Add-ins Revit directory once from another DLL file.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Message 10 of 20
smorrison7JDPT
Thank you for the reply, could you please provide direction how to replace DLL file.
Message 11 of 20
GHASEM_ARIYANI
Please download the attached file and Extract RAR file the Replace with Navisworks DLL of below path:
C:\ProgramData\Autodesk\Revit\Addins\2019
I am not sure But hopefully help
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 12 of 20
Viveka_CD
Thanks @GHASEM_ARIYANI
@smorrison7JDPT please let us know if the recommendation by @GHASEM_ARIYANI helped with your issue.
Message 13 of 20
smorrison7JDPT
Thank you for posting the RAR file. I have extracted it the folder and file and have replaced at the path provided. I am still experiencing the same issue. I appreciate your help in trying to resolve this.
Message 14 of 20
smorrison7JDPT
This seems to be only with a specific project. If I start a new project I am able to make the Navisworks command work. This was a project that was upgraded from 2018 to 2019. Is there something I can re-path within the file? Also, please note that this error is being experienced on all workstations that try to open this file. Once this file is open and this command is attempted, no other jobs are able to use the Navisworks command despite being able to run the command prior to this job being opened. Seems to be a bug within the file. Can it be purged out somehow?
Message 15 of 20
crasmussen
Was there ever a solution found for this? I am experiencing the same issue.
Message 16 of 20
smorrison7JDPT
No solution on my end yet...
Message 17 of 20
crasmussen
I found a work around but it is not easy or convenient. I was able to save me model down from C4R and detach it without worksets, save it as a template file and then start a new model saving back up, etc...At least I didn't lose any work other than losing my worksets.
Huge pain though.
Message 18 of 20
I AM HAVING THIS VERY SAME ISSUE , NEED SOME HELP PLEASE!
Message 19 of 20
Viveka_CD
Hi @Anonymous
Please post a screenshot of your error message and diagnostic data. I can send you a private upload link if you'd prefer. Let me know!
Message 20 of 20
brendan_maxwell
Autodesk. This has been a problem for far too long for too many people. PLEASE FIX THIS
