In the attached image you can see two enclosures that are a small part of a bigger project.
The lower one is correct. I can move walls and doors with no problems, but when I select them all and copy anywhere in any possible way, their mutual position gets messed (randomized?) and the result is like the upper enclosure.
If you look closely, you'll see the walls got split in sort of two groups - with correct mutual positions inside each group, but the two groups are offset to each other. Two outer walls are in one group, and the rest is in the other.
The issue only occurs with these very walls in Revit 2016.
Copying to a new model doesn't help.
Does anyone know how to fix that and does the issue even occur in newer versions of Revit? I can't check myself.
