Browser Organization: Can Sheets be moved to the top of the Browser above Views?
newurbanite
newurbanite
On Revit, once I move into Schematic design phase, I create my sheets and drop views (plans, elevations, sections, details, legends, schedules, etc.) onto the sheets. Therefore, I move from sheet to sheet frequently, and typically get into views by double clicking the view within the sheet. But since Revit's project browser default has Views at the top of the project browser above Sheets, moving from sheet to sheet always takes longer because the sheets are "buried" below all of the views in the browser. I tried to change this by moving Sheets above Views using View > User Interface > Browser Organization, but it does not seem to give me the option of changing the order of the Views, Sheets, and Schedules tabs (I don't want to reorder anything WITHIN the tabs, just want to reorder the tabs themselves). Is there a way to change the order of the Sheets, Views and Schedules within Browser Organization? Thanks
No.
constantin.stroescu
You can do it only for Sheets that contain Views...
Constantin Stroescu
mkennedy
Thank you. It's not perfect, but it works.
HVAC-Novice
Thread-necromancer! 🙂
I think the new tabbed project browser makes the problem obsolete.
Revit Version: R2026.5
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
mkennedy
Howso please?
