Brick wall color turned from red to gray
ptmcwilliams13
Message 1 of 23
ptmcwilliams13
I've been working on a model of a building everyday for a week or so. I open it yesterday morning and all my brick wall color has changed to gray. I didn't change a thing from previous and all my material and appearance settings are exactly the same as they were. I duplicated Common Brick to create these. I'm completely stressed out because I have to do a rendering presentation and don't have the time to start over. I've attached pics of walls currently and previously and my graphics/appearance settings. Help please!Current WallsCurrent WallsPrevious WallsPrevious WallsGraphicsGraphicsAppearanceAppearance
Replies (22)
Message 21 of 23
RDAOU
Message 22 of 23
RDAOU
@ptmcwilliams13
  1. If it is for Realistic View: Change the image set under the appearance tab
    • Edit the wall type >>
    • edit structure >>
    • edit material >>
    • Go to appearance tab >>>
    • Duplicate the Assit if you havent already and change the image (To another brick color image) ... there are many in the OOTB Content Library
  2. If it is for Shaded view: Change the color defined under Graphics tab (or check use rendered appearance if the color is defined there)
Message 23 of 23
@ptmcwilliams13 wrote:
The first pic is how the red brick looks now in realistic.
The second pic is how the red brick looked in realistic view before all of this happened (originally).
Both have the Use Render Appearance unchecked.  This has nothing to do with texture display.  This is for matching the Shading Color in Graphics tab (for Shaded/Consistent color visual styles) to match the Color in the Appearance tab (Realistic visual tyle).
How can I get back to how the red brick looked originally before it all turned gray. New Picture (1).jpg
So you want the second picture, not the first picture?  Then go to Appearance tab and replace the current asset with a brick asset that match it.
