- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How do I make a brick shelf at the top of a square structural concrete column?
Here's the dilemma. There are 14" x 14" concrete columns in a foundation wall with 12" concrete grade beam walls in between. There is a continuous 6" deep by 8" high brick shelf running over both walls and columns. There doesn't seem to be a way to make voids that can be turned on and off by parameter. When I created a layer of extra material to fill in the mass behind the brick shelf (see attached family) the additional portion does not appear in the project.
The visibility parameters for this additional portion are - as far as I can tell - identical to the main mass. In the project I only see the main mass. What am I missing here?
