bottom of roof with different angles
m.ruiter1974
m.ruiter1974
Hello all,
I am working on a roof that has 2 differrent angles. The back side of the roof has an angle of 59 degrees and the rest is 39 degrees.
The issue that I am having is that I get a huge vertical cut from that side of the roof with a higher angle.
I can not change the rafter cut on this particular piece of roof.
How do you guys fix this issue???
Mike.FORM
Are you talking about this vertical face? Is it too high? How are you wanting it to look? Is that face flush with the wall finish? You can always use the split face tool and then paint a portion of it the fall finish and add fascia or just use the trough you have modeled to cover the rest.
Simon_Weel
Changing the Fascia Depth might do the thing.
