blue ? question mark
Sushobhan.C
Message 1 of 17
Sushobhan.C
I created shared parameters and all is well. I get a blue ? question mark when I load the title block into my project. The problem is that I don't want a blue question mark. I want it to say something like "Input" or something to indicate that it needs to be filled out.
Replies (16)
Message 2 of 17
FGPerraudin
hi @Sushobhan.C,
Well that is what the question mark means....
François
Francois-Gabriel Perraudin
BIM management and coaching
Message 3 of 17
LisaDrago
Hello @Sushobhan.C - Are you able to modify the Blue ? If not - then it does not understand what it is associated with.
You will need to bring the shared parameter into your project as a project parameter. The image below shows what you need to do.
Once you bring it in - then you should be able to populate the information.
Let us know how it works.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: [email protected]
Message 4 of 17
Sushobhan.C
Thank u very much it works
Message 5 of 17
LisaDrago
Awesome!
Happy to hear it works for you.
LD
Message 6 of 17
Hi, I'm also having a problem with those "BLUE question marks" in the titleblock. I already added the shared parameters on the titleblock family and in the project file as project parameters but I'm having these "BLUE question marks" all over my titleblock except for those system parameters.
I can edit those "BLUE question marks" but I want the "SAMPLE VALUE" I gave them at the LABEL PARAMETERS to be visible and not those BLUE QUESTION MARKS.
PLEASE HELP. I want to provide sample value for those labels so my team would know what to INPUT in some areas of our titleblock and sheets.
Thanks a lot.
Message 7 of 17
Which category in the project did you add the shared parameters to? It must be Sheet category.
Message 8 of 17
I already tried changing the parameters in the "project parameters' list"
Project Parameters
      >parameter: Designer 1
             >Shared Parameters
                      Discipline: Common
                      Type of Parameter: Text
                      Group parameter under: Data
In the Categories list, I already tried checking:
Sheets only
Project information only
Both sheets and project info.
But nothing solved the problem of blue question mark even though it's editable. I'm using both Revit 2017 and 2016 but nothing works.
Message 9 of 17
LisaDrago
Hello @Anonymous - at this time unfortunately - there is not a way for the sample value to be shown. it is just for reference as you place the parameter.
LD
Message 10 of 17
Hi LD, thanks for the info. So for now I'll have to deal with it until a fix has been provided. Autodesk must provide a much more flexible way of using shared parameters in sheets most especially for the labels. Its annoying though having these blue question marks appearing everywhere 😭😭😭. But if something came up please do tell me a work around. Thank you 🙂
Kim
Message 11 of 17
Question marks is totally appropriate to identify labels not being entered any value.  Sample values are only to show in the family to give you the location and size of the labels so you can adjust them as needed.  Showing sample values when you load the family in you project is dangerous because all sheets can show incorrect information unless someone goes though every field and enter a value.
Most labels should have a static piece of text to tell what they are, for example DRAWN BY: <label>, CHECKED BY: <label>, etc...  If some labels stand alone and you don't know what they are for, then look in the Properties for the name of the parameters and enter the values there.
Message 12 of 17
Hi @ToanDN, Yeah that's what I like to achieve really. Everyone on my team should go through every field and must enter the correct values for each label because if they leave a blank label they will need to fill it either way. We're very careful with each information that must be provided in the sheets though.
Also, what I'm trying to do is a table of contents titleblock family providing some sample text in the list so my team would already know what format and values are to be filled already.
Ex.
<PROJECT TITLE>
<Project Address>
Table of Contents
Sheet no. Sheet Contents. Issue dates
CSD-SHWR-001. Ground Floor Plan. 07-12-17
Something like this.
Message 13 of 17
@Anonymous wrote:
...Everyone on my team should go through every field and must enter the correct values for each label because if they leave a blank label they will need to fill it either way. We're very careful with each information that must be provided in the sheets though.
Then I am afraid that you need to train your team to be getting used with question marks and not sample values because if Autodesk would make it happen then 99% of the users would be going nut.
Ex.
<PROJECT TITLE>
<Project Address>
Table of Contents
Try Sheet List schedule.
Message 14 of 17
Hi @ToanDN,
Yeah, I'm pretty sure I'll be training my Team for such things though or they should get used to it. Either way, we'll still be going to used it even with the blue question marks.
Regarding the table of contents, I already used sheet list before. Maybe I just have to polish the list or in anyway, make it easier to use without teaching my team every steps in using it. Thanks anyway.
Best Regards,
Nik
Message 15 of 17
Sushobhan.C
  1. Create new parameter- Create –Label
  2.  Create shared Parameter
  3. Save file as template.
  4. Open new template ,You will need to bring the shared parameter into your project as a project parameter.
Message 16 of 17
Hi @Sushobhan.C,
Thanks for the help but I already did that though. Now, I came up with a workaround regarding those blue question marks that are annoying even though they can be edited.
So I already have a Titleblock with labels connected to a shared parameters and I also included those shared parameters on the Project Parameters in my project which you would usually do in order for your labels to work. Now to solve the problem, every time we load the Titleblock family to a new project I used Transfer project Standards to transfer the Project Infos (which contains the data in our titleblock) to the new project so every time I would load the Titleblock family the fields are already occupied by details of another project which should be change for that certain project.
I hope you its useful though. This works for us but the drawback is that you must check each field to change the details from another project.
Message 17 of 17
Ahmed_Ramy_JBI
 Dear all, I'm still facing the same problem after doing all solutions recommended by you. What next ?
