Blue lines fro mouseover do not disappear
JudithMK
JudithMK
Hello everyone,
since using Revit 2024.1, I randomly get a problem with the mouseover (please see video attached) by the means that now the blue lines of the respective element that i hover do not disappear anymore until I change the view. This problem appears on different computers with different models, yet always with Revit 2024.1.
Is this a bug? Is there something we can do to fix it?
Thanks! Cheers,
Judith
ralphdenhaan
You can update Revit to the latest version (24.2.0.63 20231029_1515(x64) 2024.2) and see if it still happens.
Another workaround you could try is to delete that 3D view and create a new one.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
pedruccioli
As @ralphdenhaan said, try all updates. I would also note the GPU driver and Windows OS.
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
JudithMK
Thank you for your help. Updating to Revit 2024.2 has solved the problem. Kind regards
aghil_org
Community Visitor
Community Visitor
I still have same problem on revit 2024.3.0.
what is the solution?
