'Blend' Question
'Blend' Question
PhilvK
Advisor Advisor
'Blend' Question
PhilvK
When you start a blend, the icon in the ribbon shows the top highlighted in blue but you are really creating the base. When you create the top, the base is highlighted.  Does anyone else find this confusing?
martijn_pater
Don't recall tbh, didn't you drag the top below the bottom or have a negative offset?
So, what Revit version do you have? Are we talking about a model in-place or in a family (not that it matters I think).
The button just is a go-to top/bottom edit... it is obvious you're working in the other no?
Karol_Piroska
It certainly was at the beginning, you just get used to it. I guess there could be two icons for base and top (not only for this tool) to make it clearer.
MostafaElashmawy
This buttons don't show the profile that you are working on.
They are there to allow you to go to bottom when you are working on Top and go to Top when you are working on bottom.
To know which profile you are working at, look at below location.
Mostafa Elashmawy
RDAOU
@PhilvK
If you just started the blend command there shouldn't be anything to highlight...unless you are referring to the Edit Top/Base buttons on the panel (The button on the panel usually displays the opposite of what you are editing).
  1. When you start the blend it requires that one sets the base first while the Edit Top icon is displayed on the panel (one cant start with the top) => Place Base then Top
  2. When you Edit a Blend … One can select to edit either Top of Base.
    • If you edit the Base => Base profile should be highlight and on the panel you would see the Edit Top
    • If you edit the Top => Top profile should be highlighted and on the panel you would see the Edit Bottom
At least that's how it works on my screen
PhilvK
Thank you. That is what I was looking for! And thanks to all the other responses.
martijn_pater
In Revit version 2019/2020 the Edit Top and Edit Bottom button don't show simultanously as shown above. So^... I think upgrading would resolve some of your trouble? ^
