Blend between two circles in different elevation
Purus_Cdds
Message 1 of 34
Purus_Cdds
I am trying to blend between two circles. but the blend curve is not straight as i marked. Why not?
Your help is appreciated.
Replies (33)
Message 2 of 34
A blend doesn't work that way. It only has two opposing profiles.  You need to loft it.  Mass environment.
...or use 2 blends; stacked.
Message 3 of 34
ramabalanv
@Purus_Cdds,
I guess, out of your two circles (profile),  one circle(profile) is splitted. Thats why the blend profile is curvy. If you use circle for two sketches without any split, the path of the blend will be straight.
Message 4 of 34
Message 5 of 34
Purus_Cdds
That is not the case. i have both circles no (2) arcs.
Message 6 of 34
Purus_Cdds
Can you please check the attached rfa file?
Message 7 of 34
You used the wrong tool.  Don't use a Blend. Use a Sweep Blend or Revolve.
...you want it to look like this; right?  Sweep Blend shown.
Message 8 of 34
Purus_Cdds
Please check in front view. I need 9" offset between center to center as shown in the image below.
Message 9 of 34
Okay...then use a Blend.  I thought you wanted a conical shape.  You're not going to get a conical shape unless the profiles remain perpendicular to the path.
Message 10 of 34
Create two halves and join.
Message 11 of 34
@Purus_Cdds: So this is the shape you're trying the achieve?
Elevation View:
Message 12 of 34
@Purus_Cdds: I notice the your family is named Catch Basin, and that it's 10'-0" deep.  Is this a manhole?  Is so, may I submit that only one side is tapered; that the other side is parallel to, and in-line with the manhole side wall below it (the side with the ladder steps).   Something like is shown in this picture:
Message 13 of 34
Purus_Cdds
That works..! I am happy with this solution but there must be a different way.
Message 14 of 34
Purus_Cdds
Yes! that is a man hole for storm pipes.
Message 15 of 34
Well, I hate to tell you, but is that's your design objective, then your math is off.  Should be a 8" not 9" offset from center with a 3'-6" dia. man opening and a 4'-10" dia throat opening.  With 9", you have a 1 degree taper on the side opposite the major taper.  You want zero taper on that side.  Not knit-picking. Just pointing out a possible design error, that could come back to bite you in the butt.  And, it's all free advice too.  How about that?
Message 16 of 34
Ha! Yah, @ToanDN; there must be a different way! Can you work on a few more solutions and get those submitted for approval by the 8:00 AM PST? Thanks. You're the best, man.    Smiley Wink
Message 17 of 34
Hey!!! I figured out how to do the eccentric using a Sweep Blend, and it was pretty fricking easy too! Anybody still interested?  Or, are we done here?
If so, I'll share the trick with you...
Message 18 of 34
You mean this?
Message 19 of 34
...maybe. maybe not. Smiley Wink
...show me sketch mode for the top profile.
BTW @ToanDN: that's exactly what I showed above (the conical shape uses this approach).
Message 20 of 34
