Blank White Page(Activation page) on Revit 2017 startup
5 REPLIES 5
99874 Views, 5 Replies
Hello
Revit 2017 has been installed on End-User machine and while opening first time from the installation it is initializing and showing as white screen
as below, once clear the user data from C:\user\xxxx\Appdata\local\Autodesk and C:\user\xxxx\appdata\roaming\Autodesk\Revit , its showing the activcation window but it is not moving further.
Product info:
Revit 2017 Network Floating License,
Windows 7 Enterprise Operating System.
Action Taken:
  1. Clear the temp files,
  2. Graphics has been checked,
  3. Tried this :https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Regist...
  4. Antivirus has updated.
  5. Uninstalled and reinstalled.
I am awaiting for an expert suggestions here to solve this task as its strange.
Thanks in advance.
D.M.Babu
5 REPLIES 5
Did you clear the user data after reinstalling it or not ?
Try to uninstall using the autodesk uninstaller not the usual uninstall.
Make sure you have an internet connection.
If my answer helped you , please kudo and accept as a solution.
##-Hello,
I have done the cleaned in uninstallation process, so I have removed the
user data and everything.
Kindly suggest me to move further.-##
mslosar
Just ran into the same error.
Fix was/is run Revit as an administrator - right click the shortcut and choose run as administrator. Then you'll get the licensing screen. Do that, and you should be good to go.
Sounds as if you're in a locked down more than usual environment (i know i am 🙂 ) and you need rights to do the licensing portion of things.
LukeCrowson
Had the same issue.
Finally resolved it after uninstalling / clearing residual files /  reinstalling etc (Non seemed to work)
Just hit "F5" on the Activation page that has not loaded - (Refresh and should load as normal)
You can then select the licence you have - Network / Stand alone etc.
