Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Black Crop Region line
6 REPLIES 6
mwang7DKXEF
418 Views, 6 Replies
Hello
         After I create a Ceiling Legend, I drag it to the Sheet. How can I make this black crop region smaller?
Thank you
6 REPLIES 6
jay_colcombe
in reply to: mwang7DKXEF
If you activate the Legend View (Double click Inside or Right Click method or Activate View in Ribbon) can you Turn On the Crop Region and edit it by dragging the boundary shape?
alternatively
  1. In the drawing area, select the crop region.
  2. Click Modify <view type> tabjay_colcombe_0-1694984721728.gif Crop paneljay_colcombe_1-1694984721728.gifjay_colcombe_2-1694984721728.png (Size Crop).
Jay Colcombe
Autodesk Certified Instructor
jay_colcombe
After thinking it over I’m pretty sure you are limited when editing Legend cropped regions!
The Legend Boundary automatically crops the the contents inside the View so make sure in your model there are not items which could be forcing the Legend boundary to expand to fit.  Check the Reveal Hidden Elements Tool.
In the example below the Crop Boundary was tight to the square but when i copied over the vertical line it adjusted to fit tight to the new element.
Jay Colcombe
syman2000
That crop boundary depend on the family reference plane and reference line. If the reference plane and line stretch beyond the family itself, it will affect the crop region of the legend.
mwang7DKXEF
in reply to: jay_colcombe
Thank you so much.
mwang7DKXEF
Thank you so much for replaying.
I did not find "Double click Inside or Right Click method or Activate View in Ribbon" and crop region.
Thank you
jay_colcombe
I was replying on the fly, you use this method for Standard Views and does not apply to Legends sorry, hence my follow up.
Jay Colcombe
