Bim object doent show in level as cut plane
Hi
Attached small kitchen bim object
How to show cut plane ib level?
A lot of bim onject have this problem
Please help
Sahay_R
Modified Revit file attached.
Here is what was wrong - the top cabinets in your component had their visibility / graphic overrides set to be visible in plan. When they are set to not be visible in plan, then the component displays correctly -
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Hello there, there a a few ways to get around this problem:
1: the most simple one is to change the category of the family to Generic Model (Modify Tab>Family Category and Parameters)
2: If you want the family to stay in Casework Category, then you have to select the geometry above the desired view and in Visibility Settings turn of the Displays in 3d Viewa and "Plan/RCP" option.
