Big Issues for Revit 2025 Reinstallation! Please help!
pvirke
pvirke
Hi Revit 2025 Installation Experts,
I installed Revit 2025 three weeks ago, and it worked fine until the hard drive (E:) that contained Revit 2025 failed one week ago.
I completely uninstalled and cleaned all related folders of Revit 2025 and the Windows Registry as per the forum's instructions. I then attempted to reinstall Revit 2025 on a new SSD drive (D:). Despite trying all possible solutions, the reinstallation consistently fails. The installation process starts but stops at 7% - 25%, displaying various error messages such as Error 1, Error 2, or Error 1603 or 1605 ... ... before reverting to nothing.
I've never had such an issue with previous versions of Revit. I currently have Revit 2019 through Revit 2024 installed, all of which are functioning correctly. I prefer not to reinstall all of them or reset Windows.
I hope someone can help me with this Revit 2025 installation issue. Or is there a cleanup app like this for Revit 2023
Thanks!
pvirke
maybe the issue is that when I installed Revit 2025, all the other things like Personal Accelerator or Genuine Product or Autodesk Access were all upgraded and could not be uninstalled because I have so many versions of Revit which I do not want to uninstall because of I am using then nearly every day!
But I do need an expert solution on this Revit reinstallation issue!
edwin.prakoso
It looks like you need to do a clean uninstall: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall.ht...
Yes, unfortunately it will remove all Autodesk products on your computer.
Cheers,
Edwin Prakoso
Basam.Yousif
Hello
Was this resolved? and how, if you can share any info?
