Can you transfer project standards from Rev2023 to Rev2022?
3 ANTWORTEN 3
Nachricht 1 von 4
David125
243 Aufrufe, 3 Antworten
We have a new client who is requireing the use of Revit 2022, we currently have our set up on Revit 2023.
3 ANTWORTEN 3
Nachricht 2 von 4
Tom_Kunsman
als Antwort auf: David125
Just like saving a file to an older version, I do not think you can do this. Do you have an older template that you could use instead?
Nachricht 3 von 4
David125
I was trying to avoid that, we've made a lot of improvements from our earlier version in 2023. Thanks.
Nachricht 4 von 4
vitorbortoncello
You can only transfer project standards between projects opened in the same Revit session. When you open different versions of Revit, they will open separately.
Did you like this post? Don't forget to like and accept it as the solution!
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
