Best way to model these stairs
jeanettephann
jeanettephann
Hi guys,
I was wondering what would be the best way to model these stairs?
1. How do I get the side profile of the stair to follow through (as indicated in blue)
2. For the rail on the side, would it be best to have it modelled as a rail or a separate generic model. A bit complicated but it should also follow the profile of the stairs.
Many thanks.
Edit the monolithic stair run type and set run bottom to stepped instead of smooth.
The rail can be wall or curtain wall with edited profile.
Welded 3/4" Alloy Steel Plates?
Whatever. Here's another approach FWIW...
Just to be clear; the Supports are set to "None" for the Stair Type.
