Best way to cut a roof at joins?
vanderloo5
Message 1 of 18
vanderloo5
I remember seeing Paul Aubin do this by making a line at the join and cutting back to the line but these lines are very difficult to select.
Can someone show me a trick for cutting away the unseen part of this little California roof underneath. It needs to be just an overbuild roof.
Thank You
Replies (17)
Message 2 of 18
jay_colc
Modify Tab > Roof Join Tool > Click on Roof Edge and Roof Slope
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 18
vanderloo5
Thanks Jay. That worked on one side but not on the other. I've tried several times and it keeps saying can't join roofs. But I can't see why. (see attachment)
Message 4 of 18
jay_colc
I can only think that the Roof of the Left if too low for it to cut but should work, try that Face first this time does that make a difference?
Another possible solution is drag the Left Edge of the linking Roof back so it can find a Face to meet against rather than cut back?
Finally you could use the Dormer Tool which may be what you originally suggested for the side that will not join automatically
Help | Dormers | Autodesk
Jay Colcombe
Message 5 of 18
vanderloo5
Tried em all. Getting different undesired results every time
Message 6 of 18
SteveKStafford
Use Join Geometry to join the middle roof with the other two roofs. Then in a roof plan or site plan you'll be able to see the valley lines, add a reference plane at each. Then edit the sketch of each roof and modify the sketch so the boundary follows the valley edge. If the eave does not leave an edge that can be slope defining. You can create two roofs that have their slope defining edge at the ridge instead, using a negative pitch. This way the "cricket" roof between the other two can end in a "point". If you post a version of the file with just the roofs I can modify it to show you what I'm describing.
Steve Stafford
Message 7 of 18
vanderloo5
I see that somehow, in the course of my 100 attempts, the roof shrank. It should go all the way to the outside on both ends.
With that said though, I think the problem is that these two roofs are separate roofs, (see attachment),
and I can't get join geometry to work to bind them together. If I could, this operation would probably work.
Message 8 of 18
SteveKStafford
Copy the roofs to a blank file and upload it here?
Steve Stafford
Message 9 of 18
vanderloo5
Here it is Steve.
Thank You
Message 10 of 18
vanderloo5
Message 11 of 18
azad.Nanva
You can always use the mass:
(view in My Videos)
Message 12 of 18
azad.Nanva
and you can spend more time and make the clean one:
(view in My Videos)
Message 13 of 18
SteveKStafford
Here's your file after I tweaked the roofs. I used Join Geometry on each roof so the valley line remains visible while editing the roof. Have a look. There is some subtle alignment issues between them that I didn't dig into but the general concept is there.
Steve Stafford
Message 14 of 18
vanderloo5
Thank You Steve. Wondering where you see the subtle alignment issues?
Message 15 of 18
SteveKStafford
Where the three roofs meet at the bottom of the valleys and where the two parallel roofs meet each other at their valley. It's tiny, you have to zoom in to see it.
Steve Stafford
Message 16 of 18
vanderloo5
Any idea why the 2 roofs wouldn't join geometry? I think I never would have had this issue if I could have gotten them to join.
Message 17 of 18
SteveKStafford
All the roofs I need to use Join Geometry on did so without issue. I don't know why they didn't for you but I didn't have any walls in the model to interact with the roofs. It's possible that a wall that is attached to one or more of the roofs was interfering because of its own relationship to the roof(s).
Steve Stafford
Message 18 of 18
You cannot join the roof on both sides because the two joints overlap each others.  You can only do it if the two cutting roofs are farther apart than what you have.  You could simply join one side then use a void extrusion or a solid mass to cut off the roof.  Also, don't you want to remove the part of the main roofs below the gable roof to create an interior space there?
