Message 1 of 14
03:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently working on a project that requires a garden path/patio. Initially I have used a model in place for this as I thought it to be the best method. However, the gardens are going to slope along a surface and have a fall gradient. As the path/patio will need to follow the surface gradient I then thought the best way to implement the path would be to use a sub-region. The only issue with this however is that in using a sub-region instead of a model in place the path/patio is not visible in plan views.
Attached below is a quick example of how the sub-region is visible in 3D view but does not show on my plan view. Is there a way around this?
