Message 1 of 19
- Mute
- Permalink
- Report
I'm working on a roof plan and have hit a classic conundrum that I imagine many of you have run into.
I need to show the bearing walls underneath the roof to dimension the overhang distance, but I also want to keep the roof's material surface pattern (shingles) visible. I am struggling to find a clean, efficient solution that doesn't involve countless clicks or graphical conflicts.
Current Roof Plan:
Intended Result (for this small example only using the linework tool solution):
Here is what I have tried or had suggested to me so far, and why they aren't quite working for this use case:
- Linework Tool: I know I can use the Linework tool to set the wall edges to <Hidden>, which pushes them through the roof. However, I have 25+ walls to do this for, and the lines often break or become inconsistent where the walls attach to the roof. It feels highly inefficient for a project of this size.
- Plan Views: I’ve looked into using Plan Regions, but they must be closed loops and cannot overlap. I would have to create a separate, carefully sketched region for almost every wall orientation on the building, which gets messy. I also don't want to actually cut the roof; I just want the walls visible beneath it.
- Visibility/Graphics (V/G) Overrides: I tried setting the wall Projection/Cut lines to dashed/hidden in V/G, but it doesn't push the wall outlines through the roof's surface. This would be the ideal, most automated solution, but it simply doesn't yield the intended result.
- Overlaying Views on a Sheet: It was suggested that I create two separate plans, one showing only the walls (Hidden Line) and one showing the roof(s). and then to stack them directly on top of each other on the sheet. I’m hesitant to do this as it feels like a heavy-handed workaround that abuses the sheet system and makes future view management a headache.
Just to reiterate, my exact goals are:
- The roof's shingle surface pattern remains visible.
- The walls supporting the roof are visible through the roof (preferably with hidden/dashed lines).
- The wall lines are dimension-able so I can document the overhang distance.
- The solution is associative, if a wall moves or is deleted, the lines update automatically (no faking it with detail lines).
