Best Add-In for Automatic PDF Naming?
Hi, could somebody please point me in the direction of an add-in which would automatically name PDF files using data from parameters when I do a batch plot in Revit? I'm quite lucky in that the client I work for has nice short drawings numbers which are literally just <Project Number>-<Unique Drawing Number>.
Is there also a way for the PDF's to just automatically batch plot into a folder without having to manually click save on each one? Much in the same way that batch DWG exports work?
Naturally I have my parameters setup properly to name all my sheets correctly in Revit but would like to just click OK on a batch print, go make a coffee and come back to find all my drawings nicely saved in the correct folder with the correct names. The current process of manually naming and saving each file is extremely laborious.
Karol_Piroska
