BEAMS TO COLUMN CONNECTION detail
Message 1 of 15
I have drawn the beam and column in first floor level. Randomly i draw the beam and then i try to extend the beam to column on both sides, one end is connected and other end is connecting to the column .I have gap like 13mm. Even i try to uncheck the analytical mode in porperties it does not work.Please Help me out am getting this problem everywhere.
Thank You In Advance.
Replies (14)
Message 2 of 15
Sorry i have typed wrongly. Other end of beam is not connecting
Message 3 of 15
chrisplyler
I cannot tell in your picture...what is the beam? What should it attach to? Can you give a shaded 3D image with the beam selected so its endpoints are visible?
Message 4 of 15
Here am attached all the picture you need. please sort out my problem as soon as possibile
Message 5 of 15
chrisplyler
I can't tell anything from those pictures really. I need to know what families the beam and columns are. I need to see their parameters. Are they the same material? Do either of them have coping applied?
Can you attache your file for me to look at?
Message 6 of 15
Message 7 of 15
Here you go the files are attached. Yes both are structural elements. No they have different materials. But in other areas are connecting each other. I am getting this problem in rare cases. And the families are inbuilt from the revit architecture. And i did not create or download the families.
Message 8 of 15
Not sure what causing the gap but disallow join will fix it.
Message 9 of 15
chrisplyler
Weird. I fixed it by aligning the faces. But now the shape handles of the beams won't snap to the column faces at all. I HAVE to align them to get them there.
Message 10 of 15
Thanks For Giving Solution but i had one more problem that i am not getting that disallow or allow join command after i right click on the beam.
Message 11 of 15
Upload that portion of your model and we shall see.
Message 12 of 15
Its a same model but anyway am uploading once again.
Message 13 of 15
Alfredo_Medina
The "Disallow join" feature for beams was introduced in Revit 2015. Maybe you are using 2014?
Message 14 of 15
yeah your are right am using revit 2014. Is there anyother option to solve this problem in revit 2014.
Message 15 of 15
chrisplyler
You have to right click on the shape handle (the little blue dot at the end of the beam). Each end has its own allow/dissallow state.
